limesin
Aug 30, 2023Aspirant
SXS50 firmware update problem
 Hi     I have updated  SXR50 router first, before SXS50 satellite.  I have no idea how to update the satellite now, because there is no check box in router GUI to do that.  Every suggestion very welc...
- Aug 30, 2023Does SXS50 connect to SXR50 wirelessly? Or no, can you try wire SXS50 and SXR50 so you will see SXS50 is under SXR50 management.
BruceGuo
Aug 30, 2023NETGEAR Expert
- limesinAug 30, 2023AspirantHi Thx for your reply. I'm just finishing the process of restore factory settings, and I can see under SXR50 the SXS50. I will try to update and then I will finish this post. WORKED! Both items has been updated. Anyway thanks for your help!
