orbi-LAN-issues
Jul 11, 2023Aspirant
SXS80 2.5G LAN Ethernet Port 1 - Link speed limited to 1000 Mbps?
 Hi, I am using a NAS (Synology DS1823xs+) that is connected via a CAT8 ethernet cable, from the NAS’ LAN 3 port (10GbE) to the LAN 1 port (2.5GbE) on a Netgear Orbi Pro 6 Satellite (SXS80) with the l...
orbi-LAN-issues
Jul 12, 2023Aspirant
FYI there is in fact a setting to change the WAN port speed (for the router, by switching between port 1-2), so it wouldn't be too farfetched to imagine there being a similar setting for the satellite. But as you point out, the link speed would normally be determined by auto-negotiation. So I am guessing the auto-negotiation on the Orbi simply doesn't work. Or perhaps the 2.5G LAN Port 1 on the Satellite was never capable of 2.5G to begin with (despite the documentation claiming that it is). UntilI I see someone show that their Insight device management page is actually reporting that port as "Link Speed: 2500M/Full" then I have my doubts 🙂
BruceGuo
Jul 12, 2023NETGEAR Expert
Hi
We are checking this issue internally. will get back to you soon.
Bruce
- orbi-LAN-issuesJul 12, 2023AspirantMany thanks, Bruce. Much appreciated!
- orbi-LAN-issuesJul 14, 2023AspirantBruceGuo After contacting Synology again, I have received conflicting information regarding whether the NAS supports 2.5G or not. The first support agent supposedly quoted the network configuration file for the exact model that I am using, which states that 2500baseT/Full (and 5000baseT/Full) is supported. But the second support agent is telling me that it isn't, and that he has no idea where the first support agent managed to find that information. That being said, the fault may be due to the NAS, rather than the Orbi Pro 6 Satellite. I will continue trying to press Synology for a definitive answer regarding this and post an update once I have confirmed that the NAS is working as expected or not - schumakuJul 14, 2023Guru - Experienced UserAmazing support cultures in this industry 8-)
 Unless my evaluation is fundamentally wrong, and we don't face a dual network adapter designated E10G18-T2 with two Marvell Aquantia AQC 107 here, there should be no systematic reason to fail Multi Gig link speeds. Things can differ based in the adapter chip firmware on-board in a Flash, set un place during the adapter manufacturing. Read there are more factors than just the driver implemented in the Syno OS. Just read-out the theoretical possible link speeds isn't really useful...
 Granted, there are adapters built on the more reliable Inhell X550 or decent x710 chipset, also supported by Syno - but much more expensive (about 100 USD higher at least), too.- schumakuJul 14, 2023Guru - Experienced UserA possible starting point would be to use the formal driver supported ethtool to check the adapter settings as well as the base ideas for some experimenting (for the NAS side of course): Viewing adapter settings---------------------ethtool <ethX>Output example:Settings for enp1s0:Supported ports: [ TP ]Supported link modes: 100baseT/Full1000baseT/Full10000baseT/Full2500baseT/Full5000baseT/FullSupported pause frame use: SymmetricSupports auto-negotiation: YesSupported FEC modes: Not reportedAdvertised link modes: 100baseT/Full1000baseT/Full10000baseT/Full2500baseT/Full5000baseT/FullAdvertised pause frame use: SymmetricAdvertised auto-negotiation: YesAdvertised FEC modes: Not reportedSpeed: 10000Mb/sDuplex: FullPort: Twisted PairPHYAD: 0Transceiver: internalAuto-negotiation: onMDI-X: UnknownSupports Wake-on: gWake-on: dLink detected: yes---Note: AQC FW provides only information on actual negotiated pause frame usage.Link partner pause settings are not directly available.Thus, `Advertised pause frame use` actually shows negotiated settings.To see the real advertised settings, use `ethtool -a eth0`.Viewing adapter information---------------------ethtool -i <ethX>Output example:driver: atlanticversion: 2.3.1firmware-version: 3.1.78expansion-rom-version:bus-info: 0000:01:00.0supports-statistics: yessupports-test: nosupports-eeprom-access: nosupports-register-dump: yessupports-priv-flags: no---------------------Keen for some more experimenting? Try to disable autonegotiation and fix the link speed eg. to 2500:ethtool -s eth0 autoneg off speed 2500
