davidcheok
Oct 06, 2019Apprentice
Setting up satellites for static IP
Other threads have concluded that satellites pick up IP using dhcp. Can we request for the satellites to accept IP allocation by mac address? I segment my devices using static ip for permanent device...
- Oct 21, 2019
Update:
So as i had said earlier, I had reserved ip addresses outside the DHCP pool to the mac addresses of the satellites and the satellites still kept picking up ips from the dhcp pool. Well today, I just checked again and discovered that they picked up the static addresses assigned to them. Works now. I should have realised the system takes a while to work like the wireless2 issues i had previously.
This issue is resolved.
schumaku
Oct 07, 2019Guru - Experienced User
By rule of thumb, it's the "normal" DHCP server on the Orbi Pro router handling the IP allocation (as long as it's in router mode). Best guess the Orbi Pro Sxx60 User Manual p.66 - "Manage Reserved LAN IP Addresses" would allow to configure a fixed IP address (also outside of the DHCP pool AFAIK) what you want.
davidcheok
Oct 07, 2019Apprentice
Already tried that. Sats still using the dhcp pool.
- schumakuOct 08, 2019Guru - Experienced User
Rethinking my idea - dnsmasq does indeed require the static MAC-IP assignments in what they define as dhcp-range. All you can do is extend the DHCP pool (on the low or high address side) and add MAC based reservations there.
- evan2Oct 09, 2019NETGEAR Expert
Satellite can't set static IP address,
You may login SRR60's admin GUI and add satellite's MAC address to Address Reservation in ADVANCED/LAN Setup,
- davidcheokOct 09, 2019ApprenticeAlready did that. Its still getting IP from the dhcp pool. Anyway its not a big deal. Just prefer my dhcp to issue ips from the pool to non permanent devices while permanent devices be assigned from a different section.
