davidcheok's avatar
davidcheok
Apprentice
Oct 06, 2019
Setting up satellites for static IP
Other threads have concluded that satellites pick up IP using dhcp. Can we request for the satellites to accept IP allocation by mac address? I segment my devices using static ip for permanent device...
  • davidcheok's avatar
    davidcheok
    Oct 21, 2019
    Update:
    So as i had said earlier, I had reserved ip addresses outside the DHCP pool to the mac addresses of the satellites and the satellites still kept picking up ips from the dhcp pool. Well today, I just checked again and discovered that they picked up the static addresses assigned to them. Works now. I should have realised the system takes a while to work like the wireless2 issues i had previously.
    This issue is resolved.
ProSupport for Business
