davidcheok
Oct 06, 2019Apprentice
Setting up satellites for static IP
Other threads have concluded that satellites pick up IP using dhcp. Can we request for the satellites to accept IP allocation by mac address? I segment my devices using static ip for permanent device...
- Oct 21, 2019
Update:
So as i had said earlier, I had reserved ip addresses outside the DHCP pool to the mac addresses of the satellites and the satellites still kept picking up ips from the dhcp pool. Well today, I just checked again and discovered that they picked up the static addresses assigned to them. Works now. I should have realised the system takes a while to work like the wireless2 issues i had previously.
This issue is resolved.
schumaku
Oct 10, 2019Guru - Experienced User
evan2 wrote:You may login SRR60's admin GUI and add satellite's MAC address to Address Reservation in ADVANCED/LAN Setup,
evan2 The problem is that - different from many other small business routers and security appliances - the Orbi Pro (and Orbi, Nighthawk, ...) still don't allow configuring static address reservations outside of the pool intended in many network designs for real ad-hoc usage. The problem is that Netgear has carried forward poor 1990ties spec from the consumer devices - simply not good enough for this product class.
We love Netgear small business devices (switches, WAP, ...) - but stay off from the routers for this and many similar reasons.
davidcheok
Oct 21, 2019Apprentice
Update:
