duffytclown
Jan 08, 2023Aspirant
SKX50 AND MOCA CONNECTIVITY
I have a ORBI SKX50 router connected to my Verizon Business modem. Also connected to the router is a Motorola MOCA device. The MOCA device is connected directly to the Verizon router via COAX and an ...
schumaku
Jan 09, 2023Guru - Experienced User
Would not wonder a second if the MoCA boxes are causing a loop condition.
You are talking of a ORBI SKX50 router which is made up from a Orbi-Pro Router (SXR50) and one Orbi-Pro Satellite (SXS50) in this context?
duffytclown
Jan 09, 2023Aspirant
Yes, that is correct.
I agree that the MOCA could be causing a loop back. I'm not familiar with them but is there an easy way to stop that?
- schumakuJan 10, 2023Guru - Experienced User
t there a simple plan or design or sketch available on how these MoCA and SKX50 (SKR50 and SKS50) devices are connected Ethernet-wise?
