dpm416
Mar 16, 2021Tutor
SRR60 / SRS60 Firmware Version 2.6.2.200
With the automatic update of the new firmware, v 2.6.2.200, we began having issues connecting to sites on the internet. Troubleshooting showed a failure in name resolution. I noticed in the chan...
rberna3486
Mar 17, 2021Tutor
I'm having problems since firmware version 2.6.2.200 was automatically updated. It would stop connecting to the internet and the router would light magenta.
Notice the attached chart that everything was working great until my router firmware was updated! PLEASE FIX THIS ISSUE!!!!
I tried downgrading but the web client does not allow me to do this. Also the web client has disabled the ability to disable the automatic updates. WHY!!!!
- rberna3486Mar 18, 2021Tutor
It went down two times last night! I'm just wait for Netgear to response.
I'm question my future future purchases with Netgear products
- RaghuHRMar 18, 2021NETGEAR Expert
Hi rberna3486 dpm416
Please send us the debug logs or diagnostic logs ( from Insight). We will check the logs and update.
Thanks,
Raghu
- Retired_MemberMar 18, 2021
This seems to be the normal message from Netgear......send the debug logs......
- rberna3486Mar 20, 2021Tutor
I've finally have some stability since I made the change to 1 am due to daylight savings bug!!!!
Didn't your test cases account for daylight savings?
