dpm416
Mar 16, 2021Tutor
SRR60 / SRS60 Firmware Version 2.6.2.200
With the automatic update of the new firmware, v 2.6.2.200, we began having issues connecting to sites on the internet. Troubleshooting showed a failure in name resolution. I noticed in the chan...
BooJangles
Mar 19, 2021Apprentice
dpm416 Thank you for your post.
I am experiencing the same issue since the firmware update. It's definitely a DNS issue and random when it decides to occur. Some clients may experience it and others not.
To confirm it was DNS related I went to one of the clients that was having issues and manually put in a public DNS server and everything started working. When set back to auto it broke again.
I am currently setup to get DNS automatically from ISP. I chose to check the "Use these DNS Servers" box and manually entered my ISP's servers. I also manually set them in the Lan Setup and rebooted.
After the firmware update I could expect this issue to arise almost daily, after manually setting the DNS it's been 3 days now with no issue.
Obviously not ideal to have to do this.
RaghuHR
Mar 19, 2021NETGEAR Expert
Could you please check the following for your internet disconnection issue?
We are suspecting a software bug triggered by daylight saving starting from Mar 14 in the US timezone.
Can you help me confirm the issue is gone by changing the value from “0:00 am” to “1:00 am” in traffic counter setting (or you can disable it if you don't use it). See below picture.
