dpm416
Mar 16, 2021Tutor
SRR60 / SRS60 Firmware Version 2.6.2.200
With the automatic update of the new firmware, v 2.6.2.200, we began having issues connecting to sites on the internet. Troubleshooting showed a failure in name resolution. I noticed in the chan...
RaghuHR
Mar 19, 2021NETGEAR Expert
Could you please check the following for your internet disconnection issue?
We are suspecting a software bug triggered by daylight saving starting from Mar 14 in the US timezone.
Can you help me confirm the issue is gone by changing the value from “0:00 am” to “1:00 am” in traffic counter setting (or you can disable it if you don't use it). See below picture.
BooJangles
Mar 19, 2021Apprentice
Making the change and applying seems to have fixed the issue. I did not reboot.
By the way, this issue also exists for RBR50 firmware 2.7.2.104.
- BruceGuoMar 19, 2021NETGEAR Expert
It sounds good. Please monitor for a few days. You are right. We have noticed the bug impact some Orbi and Orbi Pro models because the feature uses the same library. We are fixing it.
Bruce
- Retired_MemberMar 20, 2021
When is the fix?. ....or will that be bugged as well
truly incompetent.
- wmiyazakiMar 25, 2021Tutor
I agree. These Netgear releases generally tend to add as many bugs as they purport to fix. :smileysad:
