NomadTanker
Jan 20, 2019Tutor
SRR60 Orbi Pro - Facebook wifi option not working
I have the newest firmware. The manual says I should be able to add facebook wifi. I see the option under the guest portal. However when I check mark facebook wifi. The button to add page does nothin...
- Jan 25, 2019
NomadTanker I used your terms and condition and could see correctly.
RaghuHR
Jan 20, 2019NETGEAR Expert
Hi NomadTanker
You need to click on Apply button after you click on Facbook Wi-Fi . Then Add page button will be enabled. Please confirm have you done this or not?
Thanks,
Raghu
- NomadTankerJan 21, 2019Tutor
That works. Thank you. However, it created new problems. See attachment for screen capture.
When using it this pop up shows up telling people not to use the connection.
So I tried to go back to using local Authentication mode. And it won't let me customize the logo or use terms of service.
I
- RaghuHRJan 22, 2019NETGEAR Expert
NomadTanker Could you please add the screen where you are trying to configure local Authentication mode? Is there any error when you try to customize the logo or use terms of service?
Thanks,
Raghu
- NomadTankerJan 22, 2019Tutor
It lets me browse and put in my terms and custom logo. Then I click preview and it appears the logo is right. But the terms remain netgear default.
see attachment.
