htgrimmi
Mar 09, 2024Guide
Switching SRK60 to Access Point Mode
I got my hands on a Ubiquiti Dream Machine Pro and until I can get more Ubiquiti access points, I want to use the SRK60 and satellite as access points. Couple of quick questions that I haven't been ...
- Mar 09, 2024
htgrimmi wrote:
I got my hands on a Ubiquiti Dream Machine Pro and until I can get more Ubiquiti access points, I want to use the SRK60 and satellite as access points. Couple of quick questions that I haven't been able to find on-line.
When you flip to AP mode, I assume the defined wifi networks stay? Logically yes as no way the Ubiquiti would control that.---Yes. The wifi network will have the same ssid/password
The web interface still exists but on the LAN ip that it picks up from the Ubiquiti?---Correct
Does DHCP and MAC assignment logic stay accessible on the Netgear? not sure what you mean by logic assignment but you'll still be able to view the ip/mac addresses on the orbi
Most importantly, does the relationship to the satellite stay intact? I need this in place till I get mesh capable AP's from Ubiquiti.---so long as the satellites are either using a wireless backhaul or their wired backhaul is directly connected to the orbi router , they'll still work fine.
Thanks
htgrimmi
Mar 09, 2024Guide
Quick follow up, for future readers, while it did work, you do lose a lot of the nice functionality of the Orbi. When flipping to AP mode, it went down to one SSID for 2.4 and 5. My current config has 5 SSID's, one with RADIUS and the Guest network enabled.
I did play in double NAT for a bit but the RADIUS did not allow connections. May look into that later but it obviously doesn't get me the value of the features of the Ubiquiti. In the interim, I'll just have to wait to play with the new Ubiquiti Dream Machine when I get the Ubiquiti AP's.
Mar 09, 2024Guru - Experienced User
It shouldn't.
I've used my SXR30 in AP mode and it was still able to have multiple ssid's.
- htgrimmiMar 09, 2024Guide
Tried again with a power cycle on everything after switching to AP mode.
Everything is working now with the exception of RADIUS which may be expected as it is an AP now.
All the other SSID's are visible.
I'm still going to pick up some Ubiquiti AP's as I want to move each SSID to it's own IP range and throttle networks and applications but this gets me running for now.
- schumakuMar 10, 2024Guru - Experienced User
Not at all. RADIUS auth must remain workable in AP mode.
Somewhere in the past, there was an issue in AP mode, only the SSID 1 accepted RADIUS auth. Afraid, I don't own any of the recent / last Orbi Pro systems, so can't compare, or provide the required diagnostics to Netgear. Convinced RaghuHR is interested to work on this issue.
