shejialun
Aug 16, 2023Aspirant
SXK80 - 5G-2 Channel Display Issues
what situation will the SXR80 display the 5G-2 channel option?
RennaD
Aug 18, 2023NETGEAR Moderator
Hello shejialun,
The 5GHz-2 is used for wireless backhaul and is not configurable thus the channel option is not displayed.
Have a lovely day,
RennaD
Netgear Team
- shejialunAug 21, 2023Aspirant
I'm just trying to understand the 5G-2 show and hide rule, which, based on testing, seems to have something to do with whether or not the satellites are connected
- schumakuAug 21, 2023Guru - Experienced User
Initially, the wireless backhaul was always reserved on all Orbi. On the Orbi Pro Wi-Fi 6, the community suggested to keep it dynamic, resp. allow the backhaul radio available in pure wired backhaul environments.
- RennaDAug 22, 2023NETGEAR Moderator
Hello shejialun,
As what schumaku said 5Ghz-2 for wireless backhaul will be released for fronthaul use when there is no need for wireless backhaul. But on both situation, whether satellites are on wired or wireless backhaul, the channel for 5Ghz-2 is not manually configurable.
Have a lovely day,
RennaD
Netgear Team- shejialunAug 26, 2023Aspirant
My purpose is just to understand the rules of 5G-2 showing and hiding, the actual test result so far is that without client connection, after disconnecting the satellite for 5 minutes it will show the 5G-2 channel, and after connecting the satellite for 5 minutes it will hide the 5G-2 display, but in case of connecting the client, after connecting or disconnecting the satellite, the 5G-2 showing and hiding will take a long time, it may take 1-2 hours or more, thank you.
