Randy2936
Jun 28, 2021Aspirant
SXK80 Vlan Tag
Hi need some help on setting the Vlan on SXK80. Went through the interface and it seems that it is different from the normal Orbi interface. I was following this guide and discover that i wasn't ...
Randy2936
Hi yes is the exact vlan that is required by the isp but i do not know how to set that with the SXK80 interface .
FarmerBob1
Oct 02, 2021Luminary
Randy2936 wrote:Hi yes is the exact vlan that is required by the isp but i do not know how to set that with the SXK80 interface .
I am having the same problem. To connect directly to my ONT I have to login into my Gigabit Fiber account using PPPoE with a Tagged 201 VLAN. As much as I appreciate the NG complexity which means versatility on the LAN. But as shown in all the basic NG VLAN setups, that VLAN applies to all LAN and WLAN ports with only being able to change the VLAN Port Number and Priority Designation.
I have been fighting with the over abundance of incomplete/erroneous or severely lacking information on this. ALTHOUGH, they do acknowledge that in the specs of many of these level devices like this where WAN Tagged VLANs are necessary with a good many of their users ISPs. But not a single simple paragrah, a couple lines or Pictogram of Pandas explaining what needs to be done.
Until I get it figured out, I have switched back to my Orbi RBK853. (Although it drops the setting a lot, it has a two entry setting, "apply" and done. It applies the Tagged VLAN to all 4 LAN and 2 WLAN ports.
Good Luck. I'll be watching to see if you find the answer before I do. But, I have read that this level of devices don't support this. I find that rediculous.
. . . Sir O
