Randy2936
Jun 28, 2021Aspirant
SXK80 Vlan Tag
Hi need some help on setting the Vlan on SXK80. Went through the interface and it seems that it is different from the normal Orbi interface. I was following this guide and discover that i wasn't ...
Bnjmn22
Feb 26, 2022Aspirant
Bob, did they ever fix this issue in the firmware or are you still having to use the external netgear router?
FarmerBob1
Feb 28, 2022Luminary
I have the entire RBK853 up and running trying to get an idea on any commonalities that can be used as a direction to go. I must say "there are strange things afoot."
