Randy2936
Jun 28, 2021Aspirant
SXK80 Vlan Tag
Hi need some help on setting the Vlan on SXK80. Went through the interface and it seems that it is different from the normal Orbi interface. I was following this guide and discover that i wasn't ...
Mar 06, 2022Guru - Experienced User
New FW out if this might be helpful:
I was following this guide and discover that i wasn't able to set anything on the priority .
I was following this guide and was totally stuck.
Need some advise on it.
- Bnjmn22Mar 07, 2022Aspirant
The V4.0.0.118 firmware does not fix the WAN Vlan tagging issue that is mentioned in this thread. I have it installed and it does not address the issue.
I'm currently awaiting a firmware beta from JeraldM that may address this issue. I'm not aware of the version #. I will keep this thread updated with results.
- BruceGuoApr 26, 2022NETGEAR Expert
Sorry for missing it. Do you still have the issue with v4.2.0.122? If no, please let us know. See if you want to have a call with eng team.
Thanks
