Milkysunshine
Sep 14, 2021Tutor
SXR30 Orbi Pro Mini vlan isolation issues on wireless 3 with split ssid enabled.
SXR30 + 2 SXS30 V3.2.33.108 I'm having some serious issues with my vlan setup on this orbi system. The goal is, to isolate everything on lan3 &wlan3 in the router. 192.168.30.1 is the ip for ...
schumaku
Sep 29, 2021Guru - Experienced User
Milkysunshine wrote:
If isolation were actually working, how would the devices on the iot vlan be able to reach the dns server on the same subnet?
The way I understand Netgear's simplified design (like these isolation on/off) I tend to state the isolated devices can reach the VLAN assigned subnet default gateway only, which does also serve as a DNS relay or the like. And no option to allow additional IP or MAC.
More complexity (or confusion) comes in if people add a wired backhaul, add switch ports exposing say this IoT VLAN for example as an access port, ....
Milkysunshine
Sep 29, 2021Tutor
Dupe
