Milkysunshine
Sep 14, 2021Tutor
SXR30 Orbi Pro Mini vlan isolation issues on wireless 3 with split ssid enabled.
SXR30 + 2 SXS30 V3.2.33.108 I'm having some serious issues with my vlan setup on this orbi system. The goal is, to isolate everything on lan3 &wlan3 in the router. 192.168.30.1 is the ip for ...
Milkysunshine
Sep 29, 2021Tutor
Nowhere does it state conditional network isolation if not using wired back haul.
Network isolation kinda worked, but client isolation did not at all. Wireless devices could easily see wired ones, as well as each other on the same vlan.
Even more confusion comes from the statement in the IoT wireless 3 advanced status saying "Allow IoT devices to see each other and access my local network On".
This isn't even an option to toggle on the pro mini. Looking at firmwares for other pros, it is an option that can be configured in wireless setup. For some reason, here it cannot.
Firmware is clearly an issue.
BruceGuo
Apr 26, 2022NETGEAR Expert
Hi
In the statue page, "Allow IoT devices to see each other and access my local network On" is a bug since we don't provide this feature in wireless 3 anymore. We will remove the status. Network/clients isolation are managed by VLAN/Bridge setting. Can you upgrade to v4.2.0.122 and see if you still have the issue?
