aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade. Anyone seen this ? Rega...
May 05, 2022Guru - Experienced User
Did you find any IGMP options on this switch?
nitropower
May 05, 2022Tutor
YES I made sure every IGMP setting was disabled in the Multicast header.
- FURRYe38May 06, 2022Guru - Experienced User
Ok, hopefully that should help. Keep us posted...
