hiwi
Jan 26, 2023Tutor
SXR50 tagged VLANs for SSIDs and AP mode
Hi, I'm trying to setup my SXR50 in AP mode to work with a managed TP-LINK switch to have 3 SSIDs available for HOME, STAFF and GUESTS. Each of these SSIDs would have a tagged VLAN. So: 1) I con...
- Jan 27, 2023
Is not an Orbi requirement, its the concept of vlans. Imagine each Vlan as separate LAN with a different network range. The benefit is that you can use a single port or switch to manage several networks. I forgot to mention that the ports connecting the firewall to the switch and the switch to the Orbi must be configured as Trunks.
hermesromeror
Jan 26, 2023Apprentice
I think you missed the firewall configuration. DHCP must be configured for each vlan.
- hiwiJan 26, 2023Tutor
DHCP must be configured for each vlan ?
I configured several vlan on my tp-link switchs and it have no problem.- hermesromerorJan 26, 2023Apprentice
Yes, is your firewall the DHCP server? It supports VLAN?
- hiwiJan 27, 2023Tutor
My DHCP server is a netgate and I never configured VLAN on my netgate.
Why I need configure VLAN to use VLAN on my SSIDs ?
