Tim2134
Jan 27, 2022Aspirant
SXR80 - Firmware File Incorrect
I have a new SXR80 setup with two satellites. Insight says an update is needed, but the update from the app fails. The online update page on the router shows them all as running V3.2.1.102. The...
- Jan 27, 2022
This was user error. I missed that there's a separate firmware file for the satellites - the link is in the release notes of the firmware download. 🤦‍♂️
quagmire1
Jan 27, 2022Luminary
The latest version of firmware is 3.3.0.122. You can download the firmware manually to a computer and manually upgrade the devices (satellites first, as you know) from the web interface, not from Insight.
The downloads are at:
https://www.netgear.com/support/product/SXK80#download
- Tim2134Jan 27, 2022AspirantSee above. That's what I'm trying to do.
- quagmire1Jan 27, 2022Luminary
In your post you twice referred to "v3.0.0.122" as the latest version. I incorrectly assumed you were trying to install an obsolete version of firmware - I didn't realize that was a typo and that you meant to say "v3.3.0.122".
Ah right - yes, just a typo.
