orbi-LAN-issues
Aug 24, 2024Aspirant
SXR80 / SXS80 (V4.3.3.200) - Problems with IP Address Reservation and/or VLAN / Bridge Settings?
Hi, I have two Synology NAS connected to a SXS80 satellite (V4.3.3.200), with three reserved IP addresses, and two LAGs. NAS 1 is connected via USB to an uninterruptible power supply (UPS), and t...
Aug 27, 2024Guru - Experienced User
Would removing the IP address reservation from the SXR and setting a STATIC IP address configuration ON the NAS themselves help with this?
Static IPs need to be outside of the default SXR DCHP IP address pool so you'd need to re-side the DHCP IP address range:
- orbi-LAN-issuesAug 27, 2024Aspirant
Thanks for the advice. Now that you mention it, that might be an easy way of fixing the problem. One of the NAS is busy with data scrubbing at the moment, but once done I will give this a go and see if it helps. If you happen to think of anything else please don't hesitate to share
