n17fan
Feb 05, 2022Aspirant
SXR80 only works with direct connection to modem?
With any luck, a simple question with a simple answer… Standard cable modem (Genexis DRG7820) in bridge mode Direct connection from LAN port 1 to WAN port on Orbi Pro router (SXR80) Working inte...
- Feb 06, 2022
Its more a function of your isp only allows 1 device to be connected to the modem to be assigned an ip address. The switch shouldn't be getting assigned that IP address but maybe it is. And because the switch doesn't have dhcp capability, it isn't assigning an address to the orbi.
In cases where you're doing modem only device---router then they need to be direct connected.
Why are you wanting the switch in there?
If you truly need it, you could leave the modem in router mode, add the switch, then connect the orbi in access point mode.
n17fan
Feb 06, 2022Aspirant
As a follow-up, I should have also noted that I've tried the ethernet out from the switch into the WAN port and all LAN ports on the Orbi Pro with no success
- plemansFeb 06, 2022Guru - Experienced User
- n17fanFeb 06, 2022Aspirant
Thanks for the reply – much appreciated.
The current modem also needs to support a UDM SE config (don't ask!) hence, the need to split the incoming feed. I'm aware I can run the UDM SE from the Orbi Pro instead, but client requirements are very clear in this instance.
The ISP seems to have provided erroneous info as they noted I could plug an unmanaged switch into the modem LAN port to split the feed – as you note, the unmanaged switch can't assign IP addresses so that's where the issue is.
Suspect I need to return to the ISP and get bridge mode turned off and just deal with Double NAT instead!
Great work and thanks – and no thanks to the ISP advice!
- FURRYe38Feb 07, 2022Guru - Experienced User
To help with double NAT conditions in this case, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode and Double NAT conditions can be avoided.
