n17fan's avatar
n17fan
SXR80 only works with direct connection to modem?
With any luck, a simple question with a simple answer… Standard cable modem (Genexis DRG7820) in bridge mode Direct connection from LAN port 1 to WAN port on Orbi Pro router (SXR80) Working inte...
  • plemans's avatar
    Feb 06, 2022
    Its more a function of your isp only allows 1 device to be connected to the modem to be assigned an ip address. The switch shouldn't be getting assigned that IP address but maybe it is. And because the switch doesn't have dhcp capability, it isn't assigning an address to the orbi.
    In cases where you're doing modem only device---router  then they need to be direct connected.
    Why are you wanting the switch in there?
    If you truly need it, you could leave the modem in router mode, add the switch, then connect the orbi in access point mode.
ProSupport for Business
