Anonymous
Jan 18, 2024SXR80 Wireless 2 disabled but still accessible to users
Hi there. First the tech: SXR80. Firmware V4.3.2.100 2 Satellites all on same firmware. I have 3 Wireless networks enabled: Sfeir Sfeir_Kids Sfeir_IOT Each Wireless network has its own ...
Jan 23, 2024Guru - Experienced User
You'll need to factory reset and setup from scratch. Use a wired PC and web browser to set up the SXR. Don't use Insight app. Go immediately in and uncheck the Wireless 2 option. Don't change any of the SSID just yet. Apply the change, I'd do a soft reboot of the SXR, then once back to ready, see if the Wireless 2 radio is actually need by any of your devices.
Anonymous
Jan 23, 2024That's got to be the laziest answer I've ever read. Do you realize the hours of work that would take? I'd rather throw this thing out and buy a different product if that's the only solution.
So clearly this is a bug. There should never be a time where the hardware misbehaves and the answer is: got set it all back up, including the 150 various devices on your network.
- FURRYe38Jan 23, 2024Guru - Experienced User
You should already have a backup configuration saved to file for safe keeping and in case of a need of a factory reset. Saves time if a Factory set is needed. Factory reset is a valid troubleshooting step which is necessary sometime to validate problems and also resolve them. And if you use same Wifi Configuration after the reset, devices would and shoot reconnect. Would not take hours and hours.
If you feel this is a bug, then you'll need to contact NG support.
Good Luck.
