fredmtblux
Dec 01, 2020Follower
SXS80 rebooting on and on
Hi,
I got an AX6000 sytem with 2 sats.
SXR80 router + two SXS80 sats
I upgraded to latest Firmware ( 3.1.0.104 )
It worked for a week and then now I have gor one of the 2 sats rebooting all the time :
- front led blinking white
- power led green for a while then no led (no power?) then green (so I guess it's rebooting)
I cannot see the SXS80 in the web admin portal and I t failed to sync with th main router.
I tried factory seetings by using reset button but it does not change anything (don't know if anything is happening as power led is sometimes red, amber, green with any blinking / solid combination)
Any idea how to solve this?
- RaghuHRNETGEAR Expert
Hi fredmtblux
Have you tried to connecting LAN cable directly to your SXS80 with your laptop and ping? Please confirm if you are able to ping.
Thanks,
Raghu
