LlamaLarry
Mar 09, 2022Luminary
Syslog format to use in Synology Log Center?
My SRR60 has rebooted without reason (no firmware change, no power loss/on UPS, no WAN issues) in the middle of the business day and I am trying to set up a syslog server to capture persistent logs s...
JohnC_V
Mar 24, 2022NETGEAR Employee Retired
Hi LlamaLarry,
You can setup the syslog server by going to Advanced > Administration > Logs then enable the Syslog from there. You just need the IP address and the port of the server in order for you to set it up properly. Make sure that you have your syslog server ready.
You may also check the user manual here(page 132).
John
NETGEAR Community Team
Ray-T
Mar 24, 2022Tutor
Yes, followed all the Orbi Pro instructions in the manual but like the OP, I don't get any logs recorded by my Synology NAS. As the OP said, the Synology has several options for the log's interface/format and I've tried all the combinations but have been unable to get it to work.
Orbi Pro AX6000 WiFi 6 Tri-band Router
SXK80-100NAS
Firmware: V3.3.0.122
