zippyq
Jan 26, 2023Aspirant
VLAN tagging - 802.1q?
Hi all, I'm looking at buying either a SXK80 or SXK50 system, and will be using it in "AP mode", using a Firewalla purple as the router / firewall. I want to verify though - when the Orbi Pro do...
- Jan 29, 2023
It is 802.1q.
hermesromeror
Jan 26, 2023Apprentice
Hi
I have the same setup as you described and my recommendation is to hold your purchase until netgear fixes an issue they have when using VLAN in AP mode and multiple Satellites.
Thanks
zippyq
Are you referring to the "known issue" in the V4.2.3.102 firmware, or something else?
