zippyq
Jan 26, 2023Aspirant
VLAN tagging - 802.1q?
Hi all, I'm looking at buying either a SXK80 or SXK50 system, and will be using it in "AP mode", using a Firewalla purple as the router / firewall. I want to verify though - when the Orbi Pro do...
- Jan 29, 2023
It is 802.1q.
zippyq
Are you referring to the "known issue" in the V4.2.3.102 firmware, or something else?
hermesromeror
Jan 26, 2023Apprentice
Not sure if its the know issue because I tried with only 1 satellite and it was pretty unstable.
- zippyqJan 27, 2023Aspirant
Thanks.. I need to buy now (long weird story), but won't be using the vlan functionality for a little while - hopefully the issue gets resolved by then.
- hermesromerorJan 27, 2023Apprentice
Probably the same reason than me, I bought them at a really good price...
