zippyq
Jan 26, 2023Aspirant
VLAN tagging - 802.1q?
Hi all, I'm looking at buying either a SXK80 or SXK50 system, and will be using it in "AP mode", using a Firewalla purple as the router / firewall. I want to verify though - when the Orbi Pro do...
- Jan 29, 2023
It is 802.1q.
BruceGuo
Jan 29, 2023NETGEAR Expert
Where is your issue description? I only see this "SXR50 tagged VLANs for SSIDs and AP mode". It looks a user network configuration problem. Please let me know what's your issues with topology and configuration descriptoion.
hermesromeror
Jan 29, 2023Apprentice
He means the issue included in the release notes:
- When the SXR80 router is connected to multiple SXS30 and SXS80 satellites, wireless clients that connect to wireless network 3 with the VLAN feature enabled cannot access the Internet.
Workaround: Reload the wireless configuration or disable the VLAN feature on wireless network 3.
Besides that, this is a know issue by netgear support. It has been replicated and they are looking for a solution. I had to disable the vlans on my system.
- BruceGuoJan 31, 2023NETGEAR Expert
Hi
If you reconfigue setting, the problem will not be happen anymore. What's your case ID in Netgear support system.
- hermesromerorFeb 02, 2023Apprentice
