MIchaelH95's avatar
MIchaelH95
Will several Orbi routers improve coverage?
Will additional routers improve coverage?  Can they be on network with one password?
Thanks
  • plemans's avatar
    routers or satellites?
    You can add more satellites to have them integrate with your current systems.
    • MIchaelH95's avatar
      MIchaelH95
      Thanks for your time, I was once very skilled at computer technology, but I got left behind.
      Our problem is the distances between router and satellites.  I am wondering if having a router serving the addition and a router serving the original building is the correct solution.
      • plemans's avatar
        What size is your home?
        What distance are you planning on?
        you can use a lot of satellites especially if you're using triband orbi.
ProSupport for Business
