John_Ba
Jul 18, 2024Luminary
850 and Ubos phone
We have been trying to use a Uboss internet phone setup for some weeks. Calls are basically a nightmare in how hit and miss they are. Uboss have told my ISP we are disconnecting every 60 seconds but N...
John_Ba
Jul 19, 2024Luminary
An update. It occurred to me if Armor was blocking Scanning attacks it was still active on the IP address added to the DMZ so tried turning it off. The problem went. I am running more tests as the problem isn’t constant, calls when connected are Ok and clearly when its down not!
I take it Netgear servers are partly down as the support one isn’t responding. But I can find no way of getting the Armor installed on the Orbi to ignore an IP address indeed just found lots of compliance of not being able to do anything to it over the years. If tests keep showing that’s the problem I will be left with the choise of Armor or phone.
John_Ba
I have a Uboss phone setup. Its never worked and running the Cisco box via DMZ made no change. I terned armer off and it worked, back on not working. How do you get it to not block an IP maddress?
