Dustin_V
Apr 16, 2019NETGEAR Employee Retired
Activate Your Limited Free Trial of Armor on Orbi Today!
Advanced cyber threat protection has come to Orbi! NETGEAR Armor is now available on three Orbi Mesh WiFi Systems, RBK50, RBK50V (Orbi Voice), and RBK53S. If you’re an existing user of any of ...
pbarry
Apr 27, 2019Aspirant
I'm not seeing the Armor icon in the orbi app or on the webpage. I'm on version 2.3.1.48 Any suggestions on how I can get the option to add Armor?
- DexterJBApr 28, 2019NETGEAR Moderator
Hi pbarry, thanks for you inquiry. Please make sure that your Orbi unit is not set to AP mode and is set to function in router mode.
Dexter
- pbarryMay 20, 2019Aspirant
I wanted to use Armor with Orbi in AP mode. Hopefully that will be supported in the future.
- balexkimMay 03, 2019Aspirant
Hi, why does Armor not work on Orbi AP mode? I have a Netgear cablemodem that's in front of the Orbi router so use Orbi on AP mode, but it doesn't work. When I switched to 'Router mode', it works. Can you please explain? Is it possible to work on AP mode?
