Retired_Member
Jul 20, 2022ACTIVATION CODE FOR NIGHTHAWK R6700
I was sent an activation code from netgear for my nighthawk annual subscription but every time I enter it, I get a notice that it has already been used. I can’t seem to get any support on the topic. ...
Jul 20, 2022Guru - Experienced User
Is this for Armor or Circle?
The router itself doesn't need a activation code to work normally.
Retired_Member
Jul 20, 2022The router works fine. The activation code is for the subscription software.
Thanks.
- FURRYe38Jul 20, 2022Guru - Experienced User
And what subscription software would that be for?
- michaelkenwardJul 21, 2022Guru - Experienced User
One of these?
NETGEAR Armor - NETGEAR Communities
NETGEAR Smart Home Parental Controls - NETGEAR Communities- Retired_MemberJul 21, 2022
Yes. Netgear Armor
