mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
splatooft
Oct 11, 2019Aspirant
Having same issue it seems. Internet just randomly stops. Can't access router dashboard. Unplug/plug back in, then it's back for a while. Tested all the cables, they're good. Called the ISP, no downtime of modem. Unfortunately just paid for Armor subscription.
mgdurand1
Oct 11, 2019Luminary
Exact same issue. Did all the recommended fixes with no results. Thought my router went bad. Replaced it. Same issue. Returned router and got Bitdefender to do a full refund. It is not ready for prime time. Have not had the issue since removing Armor.
- DawMattOct 14, 2019Tutor
Hi All,
Thanks for confirming I'm not going crazy.
I've only had Armor activated on my RBR50 for less than two days and I've already had 4 internet dropouts that required rebooting my router and satellite. That is more reboots than I've needed over the past 9 months in total since buying the device.
I'm surprised there isn't a firmware update for what is obviously a problem to do with this new offering they are trying to sell. I guess my free trial is going to go to waste now, because I'm not going to put up with this level of unreliablility. This new Armor offering is a nice idea but in practice it is worse than useless and I'm disabling it now.
UPDATE: I do also have the Circle option enabled. After reading another post, I'm wondering whether others in this thread also have Circle active. It is possible this internet connection drops are more frequent when multiple optional services are active on the same Orbi.
Thanks, Matt
- Orbi-RocOct 14, 2019Luminary
Hi DawMatt . As I wrote in my earlier post, the only time I experienced internet drops was when I had the daisy chain option enabled with only one Orbi satellite. If you only have one satellite, daisy chain will slow down your network and cause regular internet drops -- at least, this has been my experience. My Armor 90-day trial subscription ran out and have not yet decided to purchase a one-year subscription. However, during the trial period, I added a second Orbi satellite and re-enabled daisy chain; and everything was working fine, with no interruption whatsoever. Circle is not active, never was.
- jmorris1747Jan 07, 2021Aspirant
The same intemittent Network drops and the only fix is to reset the router. I finally disabled the the Armor on my router and have not had anymore issues.
- ShawnKRFeb 01, 2021Initiate
I'm having the same issue. Sadly, I just purchased the Armor. Ever since it has been activated I've been having problems with Internet connectivity. Oddly, my VOIP phone and email still work, just not the internet. Well, my TIVO minis lose connection to the main TIVO as well. Rebooting the router has been the only solution. I've turned off Armor to see if that fixes the problem.
- PhilipJAFeb 01, 2021Tutor
Easy fix: just disable Armor and problem goes away.
Not the correct fix of course but until they fix Armor......
