mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
jjvoliver
Mar 03, 2020Apprentice
It's not even Armor anymore, everything is broken.
I just bought an Amplifi HD system, and an extra Amplifi HD router to mesh hardwired.
I'll just put the Orbi up for sale, at 1 router and 3 satellites, I should be able to get about 300 dollars and somewhat cover some of the cost for the Amplifi.
I wish you all good luck dealing with Netgear, I'm done getting the runaround from them with serious issues like this.
Christian_R
Mar 05, 2020NETGEAR Employee Retired
Hello Community Users,
For those still experiencing issues with their Orbi system, may you confirm whether you still have Armor enabled or not. If you do/do not have Armor enabled and still are having issues, please send me a message with your serial number and contact info.
Thanks,
Christian
- dirceuguerraMar 05, 2020Aspirantis disabled and working perfectly. But shouldn't we expect it to work properly with active Armor?
- Christian_RMar 05, 2020NETGEAR Employee Retired
Hi dirceuguerra,
Absolutely! It is expected that Armor supported routers are functioning properly.
Christian
- dirceuguerraMar 05, 2020Aspirantand to make matters worse, it is not a free service. I paid and I can't use it because it limits my internet. frustrating.
