mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
Christian_R
Mar 05, 2020NETGEAR Employee Retired
Hello Community Users,
For those still experiencing issues with their Orbi system, may you confirm whether you still have Armor enabled or not. If you do/do not have Armor enabled and still are having issues, please send me a message with your serial number and contact info.
Thanks,
Christian
dirceuguerra
Mar 05, 2020Aspirant
is disabled and working perfectly. But shouldn't we expect it to work properly with active Armor?
- Christian_RMar 05, 2020NETGEAR Employee Retired
Hi dirceuguerra,
Absolutely! It is expected that Armor supported routers are functioning properly.
Christian
- dirceuguerraMar 05, 2020Aspirantand to make matters worse, it is not a free service. I paid and I can't use it because it limits my internet. frustrating.
- jjvoliverMar 05, 2020ApprenticeThat's why I decided to go a more efficient, segregated way to finally have my network setup and secure the way I wanted.
As you'll see in my first post, I already have a Cujo firewall, a Fing Box, and my mesh system. So, switched to an Amplifi HD system, and am now a happy camper. My RBK53 is going on eBay soon.
Good luck with this guy's, seems like you'll need it.
