mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
dirceuguerra
Mar 05, 2020Aspirant
is disabled and working perfectly. But shouldn't we expect it to work properly with active Armor?
Christian_R
Mar 05, 2020NETGEAR Employee Retired
Hi dirceuguerra,
Absolutely! It is expected that Armor supported routers are functioning properly.
Christian
- dirceuguerraMar 05, 2020Aspirantand to make matters worse, it is not a free service. I paid and I can't use it because it limits my internet. frustrating.
- jjvoliverMar 05, 2020ApprenticeThat's why I decided to go a more efficient, segregated way to finally have my network setup and secure the way I wanted.
As you'll see in my first post, I already have a Cujo firewall, a Fing Box, and my mesh system. So, switched to an Amplifi HD system, and am now a happy camper. My RBK53 is going on eBay soon.
Good luck with this guy's, seems like you'll need it. - Christian_RMar 10, 2020NETGEAR Employee Retired
Hello dirceuguerra,
I can assist with support reaching out to you for further investigation. If interested, please send me a private message with your contact info and serial number. In the meantime, may you let us know the current firmware version your Orbi units are on.
Thanks,Christian
