mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
HarryGh
Jun 22, 2020Guide
Had many problems dropping connection. Verified that WAN was operating well. Finally turned the Netgear Armor off. Performance is close to normal now.
mgdurand1 wrote:I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I figured I'd need a new router soon anyway, so I bought a replacement RBR50 and it set up fine. Then it dropped internet again. I did a factory reset and have not yet added Armor back in (I had purchased a year subscription). I have also had no internet drops. I want to add Armor back in but am a bit gunshy given the experience of the past week. I will likely do so soon, but am interested if I am the only one experiencing the internet drops with streaming or otherwise. Thanks.
