mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
kdharris64
Jul 17, 2020Aspirant
Same issue with my R6700v3 router. With working from home and having to connect to my company's VPN, it was dropping the connection every few minutes. I finally had to just disconnect the router altogether and wire my work laptop directly to the modem until I figured it out.
I reset to factory settings and did not re-install Armor. No problems. I like the concept, but it definitely wasn't stable enough to release.
I hope I can get my money back! Hopefully they will resolve the issues with Armor and i will give it another try...someday...
Kelly
- HarryGhJul 17, 2020GuideHad the same problem. Had to constantly reset it.
Will not be using armor anymore. It is a good idea executed poorly.
