mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
jmorris1747
Jan 07, 2021Aspirant
The same intemittent Network drops and the only fix is to reset the router. I finally disabled the the Armor on my router and have not had anymore issues.
ShawnKR
Feb 01, 2021Initiate
I'm having the same issue. Sadly, I just purchased the Armor. Ever since it has been activated I've been having problems with Internet connectivity. Oddly, my VOIP phone and email still work, just not the internet. Well, my TIVO minis lose connection to the main TIVO as well. Rebooting the router has been the only solution. I've turned off Armor to see if that fixes the problem.
- PhilipJAFeb 01, 2021Tutor
Easy fix: just disable Armor and problem goes away.
Not the correct fix of course but until they fix Armor......
- jmorris1747Feb 01, 2021Aspirant
Yep...thats what I did to get it to work....I was rebooting the router daily until I disabled Armor....needs work not ready for release.
- ShawnKRFeb 01, 2021Initiate
jmorris1747 wrote:Yep...thats what I did to get it to work....I was rebooting the router daily until I disabled Armor....needs work not ready for release.
Hard to believe they have not addressed this problem since this thread is already 2 years old. If they have a problem like this it makes me wonder how effective their software is.
