mgdurand1
May 19, 2019Luminary
Anyone seeing internet connection drops with Armor enabled?
I installed Armor on my 2 1/2 year old Orbi and started having internet drops once I streamed content on my TV. I had the same issue when I thought I had removed Armor but apparnetly I had not. I f...
ShawnKR
Feb 01, 2021Initiate
I'm having the same issue. Sadly, I just purchased the Armor. Ever since it has been activated I've been having problems with Internet connectivity. Oddly, my VOIP phone and email still work, just not the internet. Well, my TIVO minis lose connection to the main TIVO as well. Rebooting the router has been the only solution. I've turned off Armor to see if that fixes the problem.
PhilipJA
Feb 01, 2021Tutor
Easy fix: just disable Armor and problem goes away.
Not the correct fix of course but until they fix Armor......
