Ransak
Nov 14, 2021Aspirant
App confusion
 Is anyone here?   I have a CBR750 modem/router and have the upgraded VPN via the Bitdefender mobile app. After online chat with NG, I uninstalled that VPN and went through the VPN installation via th...
Dec 01, 2021Guru - Experienced User
I recommend you ask NG support again on which app that your supposed to use and what the results are supposed to be for being protected.
Not alot of posts or users posting with this same configuration so hopefully NG support will be more helpful.
