Infinite383
Sep 11, 2024Aspirant
App lock issues - switched lock/unlock icons
I've been noticing some rather strange behavior and would love to gain some insight...I've been using the armor app for several months on my Samsung android phone, as I've suspected some security issu...
Sep 11, 2024Guru - Experienced User
Is that seen with in the Armor feature app in Orbi or Nighthawk app or is this in the Android OS window app?
What NG router model do you have?
What model Samsung phone do you have?
What OS version is loaded on the phone?
Infinite383
Sep 13, 2024Aspirant
Okay, sure.
-This is on the Armor app, version #16.0.0.
-Andriod A35, UI 6.1, Android 14
-Did have a Nighthawk router, though no longer used. I would assume the app does not require a NetGear router to function-?
Thanks again!
Thanks again!
- FURRYe38Sep 13, 2024Guru - Experienced User
Okay, if you don't have a NH Router, then Armor will not work. It's only intended and requred for NG Nighthawk or Orbi router systems.
