Infinite383
Sep 11, 2024Aspirant
App lock issues - switched lock/unlock icons
I've been noticing some rather strange behavior and would love to gain some insight...I've been using the armor app for several months on my Samsung android phone, as I've suspected some security issu...
Infinite383
Sep 13, 2024Aspirant
Okay, sure.
-This is on the Armor app, version #16.0.0.
-Andriod A35, UI 6.1, Android 14
-Did have a Nighthawk router, though no longer used. I would assume the app does not require a NetGear router to function-?
Thanks again!
Thanks again!
Sep 13, 2024Guru - Experienced User
Okay, if you don't have a NH Router, then Armor will not work. It's only intended and requred for NG Nighthawk or Orbi router systems.
