allesschonweg
Feb 19, 2025Aspirant
AppArmor cannot be deactivated once the subscription ran out
Hi, as I upgraded my pihole I have seen that all the requests come from the Router instead of the clients. Then I remembered, that the Orbi acts as DNS Proxy as long as AppArmor is activated. So...
allesschonweg
Not if the subscription ran out... then you only get the page to make a new subscription. Thats the problem.
Feb 19, 2025Guru - Experienced User
Ok, have you powered OFF the RBR then back ON? if the sub expired then this should disable armor on the system.
Might try a factory reset of the system and then setup from scratch with a ethernet connected PC and not the Orbi app.
This would clear out any Armor features left behind.
- allesschonwegFeb 19, 2025Aspirant
On/Off doesnt help, had a power outage yesterday, so I am pretty sure..
And yes, a factory reset should help, but this can at least be seen as bug report.
- michaelkenwardFeb 20, 2025Guru - Experienced User
Anything useful here?
NETGEAR Armor powered by Bitdefender
It is the Security Dashboard
Disclaimer: Just another user with time on their hands.
- allesschonwegFeb 20, 2025Aspirant
Nope, had a look there yesterday too
