Wolfi1952's avatar
Sep 29, 2021
Armor + Bitdefender on PC
I have installed Armor on my ORBI and all my PCs are protected using the Bitdefender Internet Security. Now Armor tells me that I should install Bitdefender Internet Security on my PCs, trying tha...
  • Wolfi1952's avatar
    Wolfi1952
    Oct 12, 2021
    Hi,
    meanwhile I got the solution. There is no way to tell armor that the Bitdefender has already been installed because licenses installed form armor use a different registration platform. So the only way to solve that is uninstalling the Bitdefender product including the agent and vpn and afterwards install the same software downloaded from the armor website. It takes some time depending on the PC's speed, but it works without problems. During the installation you need the armor login, that's all.
    Installing the software on a mobile device is a straight forward procedure running without any problems.
    Best regards
    Wolfgang
