blakey84
Nov 10, 2022Guide
Armor badly affecting Xbox series x
I’ve spent all evening trying to figure out why my wired Xbox series x was downloading and carrying out speed tests so badly, it was hitting between 40 Mbps and 200, completely wild, each test would r...
blakey84
Nov 10, 2022Guide
Hard to tell at this stage if this is a bug with the beta, I'll try and carry out some more testing tomorrow.
However, I'm finding with Armor enabled, my wired performance on my Xbox Series X is dreadful, terrible speed variations between 30 and 180 Mbps, bad pings. I tried changing cables, looping out my unmanaged switch.
The moment I turned off Armor... 950+ Mbps each and every time. Turn it back on... problem comes back.
I might try to roll back to the current release and see if the problem persists.
