gmcotton
Mar 28, 2020Guide
Armor Bitdefender
I had disabled Armor after it kept causing 2 of my printers to spew out pages during a scan. After reading that the current firmware that is in my Orbi RB50 had solved the problem I turned Armor ...
Christian_R
Mar 31, 2020NETGEAR Employee Retired
Hello gmcotton,
Thanks for sharing your experience. I have not seen similar reports of this issue. If you'd like, I can see if support can reach out to you to provide any assistance with Armor. If you're interested, please send me a private message with your contact info and serial number.
Thanks,
Christian
- gmcottonMar 31, 2020Guide
Thank you for the offer. However I have resolved the issue, by removing the offending software from my systems. I'm sure that support would want me to reinstall the software to see if the problem replicates. After the many hours it took to restore the systems, I will not take that chance.
Gordon
