rahanna
Nov 05, 2021Aspirant
Armor Blocking Helium RAK Hotspot
Hi everyone, I installed a Helium RAK hotspot on my Orbi Network and Armor is blocking all traffic to it. I tried to set it IP on the DMZ but still no go. It there a way to make an Exclusion on Ar...
Nov 06, 2021Guru - Experienced User
have you tried going in an allowing devices?
NETGEAR Armor is blocking URLs that I want to access; what do I do? | Answer | NETGEAR Support
rahanna
Nov 06, 2021Aspirant
Thanks plemans ... I did unblock the sites several times but they do change randomly.
What I'm looking for is a complete EXCLUSION for the Helium RAK Hotspot which is already assigned an address of 192.168.33.200 behind the Orbi.
How to make this local IP [192.168.33.200] free and clear from any ARMOR blocking ?
I am sure that similar people had issues with IPTV devices so I'm hoping that there is a solution for that.
Thanks everyone for offering to help !!!
- plemansNov 06, 2021Guru - Experienced User
with the helium being on the 192.168.33.*** address. Did you change it or does it have its own dhcp built into it?
Not sure how armor responds to it being changed from the default LAN range.
