TWHBW
Aug 20, 2021Tutor
Armor Blocking Repetitive Port Scan Attacks on Google Nest Hub
I keep getting port scan attack notices (every 5-10 minutes for two days now) from Armor regarding two Google Nest Hubs we have. When I go to check the information in the app, the app says "something ...
Filmer
Sep 01, 2021Aspirant
Hello,
I ran in to this same issue as well. I'm not sure if this is the actual problem, but I had one of my google hub displays set to show a picture slide show. I changed that setting to only show the clock. I haven't gotten any other blocked attacks from that display, it's been about 4 hours. We will see if that's actually resolves the issue (a software fix is still needed)
